Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Checkboxes / check marks not visible in distance menu in Tinkercad mode
3 REPLIES 3
thomasa88
421 Views, 3 Replies
I have set Pan, Zoom, Orbit shortcuts to Tinkercad in Fusion 360.
Now, when I use the dimension tool and right click, the checkboxes are no longer visible.
The behavior is not affected by Use gesture-based view navigation on/off.
Tinkercad:
Fusion:
 Steps to reproduce:
  1. Set Pan, Zoom, Orbit shortcuts to Tinkercad
  2. Create a sketch
  3. (Draw a circle)
  4. Select the Dimension tool
  5. Right click
2.0.8624
Active Plan: Fusion 360, Personal
Windows 10 (18362)
Labels (3)
3 REPLIES 3
jhackney1972
in reply to: thomasa88
I can replicate the issue using your process.  The only addition to the process is to pick the Dimension Tool, then the circle and then right click.   The function in the context menu seem to work but as stated there is no check box indicators.  @jeff_strater , you may want to take a look at this.
John Hackney, Retired
jeff_strater
in reply to: jhackney1972
Yep, so can I.  Thanks for the mention, @jhackney1972 .  I created FUS-56733 for this one.  Very weird...
Jeff Strater
Engineering Director
thomasa88
in reply to: jeff_strater
Thanks!
Just because I like speculating: It looks like the Tinkercad menu is drawn in a completely different way. (Look at the separators, the hotkey indicators and the outline).
