Announcements
Character Holes not showing in Fusion360
I have designed a desk organizer in tinkercad with my name initials (Y-A-N-N-I) as holes in it.
The same file when I had opened it in Fusion360, the holes didn't appear.
But when I had opened it in SolidWorks , the holes were present.
I have attached three pictures for reference -
1.  Desk Organizer(1) which is the output in tinkercad.
2. 360 which is the output in fusion360.
3. SW which is the output in Solidworks.
Before getting it 3D printed, I wanted to cross-check the design to avoid compatibility issues, and I noticed this.
I would be really grateful if someone explained why this has happened so that I can avoid major setbacks in the future.
g-andresen
Fusion has problems with some font formats*.
Workaround:
1. test it with a different font (OTF)
2. transform the Text > right click > Explode
3. share your file
günther
* e.g with TTF Fonts
HughesTooling
Are you exporting from tinkercad then opening in Fusion of redesigning in Fusion? If you are exporting From tinkercad, what format are you using and can you share the file here?
Mark
Mark Hughes
Owner, Hughes Tooling
