Change simulation Transparency Opaqueness
stylz67
stylz67
Using current updated version of Autodesk Fusion Personal (updated yesterday).  Model always appears how I want and changes from solid to transparent (wireframe), to shaded with visible edges, etc. with no issue.  When going into Simulation however, it is always at (by the looks of it and guessing) 50% transparent.  I can't figure out how to make the simulation stock appear solid (non-transparent).  Should be a simple answer I'm overlooking.  Found several good answers on the forum, but they were from 2022 and prior, which is different than current version and pull down menus of Fusion Personal.  Thanks for any help.
stylz67
Cleared memory cache and reboot.  All works properly now.
