Center (Vertical and Horiztonal) Alignment of 2 Bodies - Hinge
akerezy
akerezy
  I am trying to make a triangular shape, with 3 print in place hinges. The center of the triangle has a hole, that allows it to be placed onto a mic stand. Each of the hinges will have a short threaded rod into them. I made hinges because I want to be able fold them up, and fold them down.  Parts and Challenges. Originally I made the triangle, the "butt" of the hinge, and the hinge post which aligns and fits over the hinge pin - as 3 separate bodies and components. As I thought about printing it, I have combined the triangle and hinge butts (with the hinge pin) together, with the hinge posts being kept as separate bodies.
   HELP - How can I align each of the hinge posts; horizontal and vertical alignment - so they fit exactly in place over the hinge pin.   See Attached Pics
I have repeatedly TRIED to upload the Fusion file - but the website says the extension doesn't match the file format?
UPDATE ---  I have attached the f3z file in a zip file.
Thanks In Advance
Replies (9)
davebYYPCU
Move - Point to Point, selecting the centre point of each cylinder.
Joint them the same way if they are Components.
Might help...
g-andresen
@akerezy  schrieb:
I have repeatedly TRIED to upload the Fusion file - but the website says the extension doesn't match the file format?Inserted (linked) components can prevent the upload as f3d.
Remedy: Right-click > break link (only for exporting as f3d)
Günther
akerezy
I appreciate your help, but I think you have different software than I do.
Right-Click -> Break Link.....
  exactly "WHERE" do I right click?
My software has only an f3z file extension option. I have no f3d export option.
akerezy
Thank you for your reply. I've used and seen the MOVE/COPY dialog window.....and never used the Point to Point option.
 ..........however......  for the vertical alignment; my hinge post has no points to align to the center point of the pin; see attached pic
davebYYPCU
You must first select what to move, hover over the cylinder walls and the centre points will be revealed.
Save the f3z file and convert to a Zip file to attach.
Might help….
g-andresen
günther
davebYYPCU
Works as mentioned.  After hoving over the body parts, hold down the Control key, so you can move directly to and select the midpoints.
Might help....
akerezy
   WOW..... it's so easy. First.... I didn't know that hovering over a body, while holding down the control key lets you identify the points. Thank you.
I am finding very hard or impossible to get the center of these two because for one of the hinge parts the center is cut away, and for the other with my section analysis on the center point of the cylindrical hinge post isn't visible.
ahhhhhhh
Any Suggestions to ASSURE the alignment of the center points is easy?
Frustated
AJ
g-andresen
try it this way
create joint between faces.mp4
Video Player is loading.
Current Time 0:00
Duration 1:52
Loaded: 8.84%
Stream Type LIVE
Remaining Time 1:52
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    günther
    Type a product name
    ______
    icon-svg-close-thick
    Cookie preferences
    THIRD PARTY SERVICES
    icon-svg-hide-thick
    icon-svg-show-thick
    Qualtrics
    Akamai mPulse
    Digital River
    Dynatrace
    Khoros
    Launch Darkly
    New Relic
    Salesforce Live Agent
    Wistia
    Tealium
    Upsellit
    CJ Affiliates
    Commission Factory
    Typepad Stats
    Geo Targetly
    SpeedCurve
    Qualified
    icon-svg-hide-thick
    icon-svg-show-thick
    Google Optimize
    ClickTale
    OneSignal
    Optimizely
    Amplitude
    Snowplow
    UserVoice
    Clearbit
    YouTube
    icon-svg-hide-thick
    icon-svg-show-thick
    Adobe Analytics
    AdWords
    Marketo
    Doubleclick
    HubSpot
    Twitter
    Facebook
    LinkedIn
    Yahoo! Japan
    Naver
    Quantcast
    Call Tracking
    Wunderkind
    ADC Media
    AgrantSEM
    Bidtellect
    Bing
    G2Crowd
    NMPI Display
    VK
    Adobe Target
    Trendkite
    Hotjar
    6 Sense
    Terminus
    StackAdapt
    The Trade Desk
    RollWorks
    Your experience. Your choice.
