Hello , When I render in canvas render and save the image , after the image is been saved the image is full black . It deos not capture the image . Help me out .
Hello @sanket223.patil,
thanks for posting! I understand that you are having issues with the output image of your in-canvas renderings. Just to clarify - is the whole image black, or just the object you are trying to render?
Let me know if this helps. If the issue persists, share your Fusion 360 design with me so that I can try and reproduce it. Thanks in advance!
Please accept as solution if my post resolves your issue, or reply with additional details if the problem persists.
Best regards,
I have finished a couple of in-canvas renderings and saved in all three formats but I cannot reproduce your issue. One guess, you did not say what application you were trying to view the rendered image, but try another and/or make sure the one you are using can open another source image of the same type.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
I have used the incanvas alot , but after reinstalling the fusion , the incanvas output is not working . the image is full black . In every format , the output image is fullblack . what to do , i think there is some issue with my fusion
@pawel.potyrala wrote:Hello @sanket223.patil,
- Which format are you saving the file to?
- Are you saving the rendering locally (hard drive) or uploading it to the cloud?
- Are you using custom appearances? If so, have you investigated the brightness of the source image?
Best regards,
I tried every application , But the image is full black . The output of incanvas is not working .
thanks for the update. Could you record a short screencast presenting the issue (see Autodesk Screencast) and share the link to the design with me (How to share a Fusion 360 design), so that I can try and reproduce the issue?
Thanks in advance!
Best regards,
I have send a link for screencast , There is my issue . In any format I export its black . https://autode.sk/2A3DEsH
thanks for the screencast! I can see you are using a custom environment for your rendering. Could you try the following:
Let me know if that helps. If the issue persists, share the link to the design with me and send me the file with the custom environment you are using for your rendering. Thanks!
Best regards,
Hello , its not a custom . Its the field . And even When i use default , the output is same . what to do ?
thanks for the update. I was not able to reproduce the issue for the "Field" environment, either.
I'm curious if this is reproducible for the specific design you are working on. Can you share the link to the design with me? Here's the instruction: How to share a Fusion 360 design
Thanks in advance!
Best regards,
Hello Sir , Its not about that specific model . For every model , the issue is same . I cant output the image .
