When in design mode, I can select all the bodies in my design.
When I go into the 3d printer section to export this as a .stl file...I can only select 1 body at a time to export, which in turn will not print correctly on the 3d printer.
I have tried to drag and select in both directions, hold shift and click on the bodies, and hold control and select all the bodies, but only 1 body will select at a time for some reason.
