I am struggling to draw a stamp that the letters taper to sharp point.
I have tried various fonts that I can extrude no problems but when I try to taper the extrusion to a point I get height differences due to the different widths of the fonts. (see attached BPic.png)
I have tried many different fonts and even tried downloading "monoline" fonts but none seem to be equal widths.
Does anyone know how to do this?
Steve
Solved by wmhazzard. Go to Solution.
What I would do is explode the text in a sketch, then use the offset tool to draw the inside of the letter at a consistent width and extrude from there. See the attached file.
Hi
Thanks for that. Not a bad way of doing it for occasional single letters or short words.
I would however also like to be able to do this quickly and easily for longer sentences or addresses. I intent to make custom branding irons for leather or wood projects. I am hobbyist and will try to work out if your method can be adapted to do multiple letters when i get some time.
Once you got the 26 letters done, you can insert as many copies of each letter that you need for a sentence and use joints to place them.
