i cant do anything more then this as it wont let me, even though it knows i have a team
Solved by rangt. Go to Solution.
I'm very sorry you're experiencing this. We are looking into it now.
Could you post your log files in the event the team needs them?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-and-sh...
the instructions on how to manual find the logs are to confusing and i cant do it through the app as i cant access the app as what i have screenshotted blocks me
I'll check into the instructions.
There was another update to Fusion published overnight that is expected to solve your problem. You can uninstall the current Fusion client from your machine and re-install. I hope that gets you running again.
I apologize for all of this. Certainly a full uninstall and re-install is not an easy or friendly solution. We know that and appreciate your patience. We're all working to do better.
