I have a sketch in fusion 360 that I exported from fusion 360 to DXF. I would like to cut this design on my laser cutter.
When I try and open the DXF file in my laser cutter software it does not view the correct design. I then tried and view the DXF file in Solidworks but the result is even worse. See the attaches screenshots.
How did you export? It looks like it's edge on in Solidworks. Can you share the f3d and DXF here? You'll have to add the DXF to a ZIP file to attach or the forum software will block it.
Mark
Mark Hughes
Owner, Hughes Tooling
I just exported. There are no options when exporting except for selecting the file format. For which I selected DXF.
F3D and DXF files attached
yes, it seems like solidworks is interpreting the file from the side. But I'm not bothered about solidworks. I would like to cut the file in my laser software
You may even try the laser software: https://sinjoe-com.s3.amazonaws.com/1512027375815_Sinjoe_LaserCAD_V7.95.5B_3D_Grey_Scanning_Engravin...
In Fusion, right click the sketch in the browser and select Save As DXF. Think this is where you went wrong.
Mark
Mark Hughes
Your DXF is OK it's just on the XZ plane. If you export the sketch from the browser in fusion it'll be on the XY plane and should work for you.
Mark
Mark Hughes
