Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Cannot Read results after "Measure" - Rusults in black font always placed over object.. how to change?
4 REPLIES 4
236 Views, 4 Replies
Greetings Folks,
I am having an issue using the Measure tool. The results are always displayed hovered directly over the object and very difficult to read sometimes (see example). Is there any way to configure F360 to display these figures offset from the model, like out in the blue workspace area? Ior is there a way for me to "drag" these figure to any position. Can I change the Font color maybe?  This habit of displaying the results (in black font)  directly over the dark object which contains black lines renders the tool almost useless.
Thanks in advance!
-t
Greetings Folks,
Thanks in advance!
-t
4 REPLIES 4
jeff_strater
jeff_strater
no, unfortunately, there is no way today to reposition the measurement, or change its display at all.  Usually, if you rotate the model, you can see the results more clearly.  Also, the results are also displayed in the Measure dialog, where they can be seen, copied, etc.
Jeff Strater
Engineering Director
Jeff Strater
in reply to: jeff_strater
Yes, thats what I have been doing... Rotating it around until I get it in a position where I can read it. I KNow it is at the bottom right of the screen of the screen - but that does not display the second increment. I will look into the actual dialog box...
jhackney1972
jhackney1972
I use the Environment "Gray Room" and the measure dimensions come up in white, maybe this setting will be better for you.
John Hackney, Retired
in reply to: jhackney1972
That should work perfectly... I will try out the grey room when I get back home..
Thanks kindly to everyone for the help
and have a great Christmas ALL!
-t
-t
