Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Cannot move an inserted component
3 REPLIES 3
ajarizaleta
150 Views, 3 Replies
Once I insert a component in current design I cannot move it.
I created a simple body representing a part. I insert the component in another design.
When it's inserted the component can be moved around. Once accepted in a position, I tried to move it but it's just moving an undetermined point, similar to a pivot point in coordinates moving, but the component itself doesn not move. Meaning: the component only moves when inserted
Thanks in advance
3 REPLIES 3
g-andresen
in reply to: ajarizaleta
Rightclick >  "unground from parent"
günther
jeff_strater
in reply to: g-andresen
and, while you are at it, turn off the preference that created this in the first place:
Jeff Strater
Engineering Director
ajarizaleta
in reply to: jeff_strater
Thanks Jeff, that made it
