cannot log into Fusion after update - error inside web browser redirect back to Fusion
cekuhnen
Mentor Mentor
Message 1 of 10
cekuhnen
macOS 13.3.1
Updated Fusion today
What my opinion about the stability of this new web log-in is I keep for myself.
I did deinstall and reinstall Fusion360 too - no difference ...
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Replies (9)
Message 2 of 10
RajkumarIlanchelian
@cekuhnen @If you go into launchpad in your max and look for Fusion service utility, in there you will have option to gather log file. Can you please attach the diagnostic zip file that it generated here, please ?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 10
cekuhnen
@RajkumarIlanchelian Good morning. I do not see that option - only gather system info.
Claas Kuhnen
Message 4 of 10
cekuhnen
also 35 minutes later the system still is gathering data ...
Claas Kuhnen
Message 5 of 10
RajkumarIlanchelian
@cekuhnen @Ok. Then let’s try a different approach.
please go to the below article and service log files -ID service shows where to find the particular log we would like. Please post that here.
Autodesk Fusion
Join Fusion Insider
Message 6 of 10
RajkumarIlanchelian
@cekuhnen @While we wait for logs here are a couple of other things if you can try that will help find what is happening.
1. Can you change the default browser to some other one than what you are using now ? If that works then we know it is likely some setting I. The current default browser.
2. If you go to Finder - Go to folder - type /private/tmp is there an Autodesk identity manager folder in there? If there is one can you right click on the tmp folder and see if there is enough read and write access?
Autodesk Fusion
Join Fusion Insider
Message 7 of 10
cekuhnen
EDIT: I was able to finally log in -
I moved the default browser to Safari -
the engine asked for an account manager and all froze again
I force quit Fusion and then it launched again without asking me to sign in again
looks to me this new method is pretty fragile when this can happen
Claas Kuhnen
Message 8 of 10
RajkumarIlanchelian
@cekuhnen @Was the previous default chrome? It would still be good to know your previous default browser and the log files. We should still be able to get you back on your preferred default browser.
Autodesk Fusion
Join Fusion Insider
Message 9 of 10
cekuhnen
In that folder is no Autodesk identity manager folder
switching back to Safari makes all work now without any hangs
Claas Kuhnen
Message 10 of 10
YouRQXXL
Observer
Observer
I have the same problem on Windows 10 + Chromium.
Changing default browser to Edge give mi chance to log in but i don't want Edge as default browser 😞
