Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Cannot install Fusion 360 with HTTP Error 404
30 REPLIES 30
Message 1 of 31
2961 Views, 30 Replies
I created an account as a design competition mentor (for FTC), I was able to download the dmg for Mac and start the installation, however, at ~14%, I got the error, HTTP 404, it seems a file cannot be found on the server. I attached the screenshot and the log file.
2019-03-11 19:23:46,814 - MainProcess(16068) - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: /Users/langao/Library/Application Support/Autodesk/webdeploy/shared
2019-03-11 19:23:47,709 - MainProcess(16068) - Thread-5 - adsk.dls.streamer.process - INFO :: package installation complete
2019-03-11 19:23:47,711 - MainProcess(16068) - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d25e24b247d3adf872742c7d4fc86da489395fe2.ta... for package d25e24b247d3adf872742c7d4fc86da489395fe2
2019-03-11 19:23:47,834 - MainProcess(16068) - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: /Users/langao/Library/Application Support/Autodesk/webdeploy/shared
2019-03-11 19:23:48,155 - MainProcess(16068) - InstallDriver - adsk.dls.streamer.process - WARNING :: Exception fetching package manifests: HTTP Error 404: Not Found, url:https://dl.appstreaming.autodesk.com/production/packages/e89cca5f0073f850bb9663ce91e956289f3915a0.js...
2019-03-11 19:23:48,155 - MainProcess(16068) - Thread-1 - adsk.dls.streamer.process - INFO :: Failed to start executing tasks thread
Lan
30 REPLIES 30
Message 2 of 31
Can someone please help with this.. I am having the same issue trying to install Fusion 360
Message 3 of 31
RajkumarIlanchelian
We apologize for the errors. We have since fixed the errors and restarting Fusion 360 should successfully get you the update. Please let us know if you continue seeing the problem.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 4 of 31
in reply to: RajkumarIlanchelian
Thanks a lot! It is fixed now and I just finished installing it.
Message 5 of 31
joshbg2k
I am having this issue too. Not much info to add, but I did create a new account to use the trial, and then I realized I have an older account and want to use that. When I uninstalled the version using the bad account, and reinstalled with the account I want to use, I get the error.
Message 6 of 31
adrian.gersbach1
in reply to: joshbg2k
I too am having this issue as well.
Message 7 of 31
We are aware of this issue and apologize for the inconvenience. We are working at this time to fix it. I will report back here when we have done so.
Autodesk Fusion
Join Fusion Insider
Message 8 of 31
Message 9 of 31
morgan5V3DZ
Same problem for me..
Changed name on my Windows user and want to install Fusion but nah.. Getting server problem when I start the installation..
Message 10 of 31
i have the same issue
Please help.
Attaching log file and error screen shot
Message 11 of 31
I have this problem installing in Mac OS Mojave.
Message 12 of 31
RajkumarIlanchelian
The install should be fixed. Please reply back here if you are still experiencing the issue.
Autodesk Fusion
Join Fusion Insider
Message 13 of 31
I'm having this issue now, can you help me please.
Message 14 of 31
RajkumarIlanchelian
@Anonymous What error are you facing? I know the title says one thing but the discussion below branched off into others. If you are on 10.12 OS X then we have officially blocked install on that version.
Autodesk Fusion
Join Fusion Insider
Message 15 of 31
it's 404 errors and my system is 10.13.6, is it blocked as well
Message 16 of 31
RajkumarIlanchelian
No. 10.13 is supported. Let me take a look.
Autodesk Fusion
Join Fusion Insider
Message 17 of 31
RajkumarIlanchelian
@Anonymous We have checked and we can successfully install on 10.13 machines. Can you please capture the error you are receiving? Does it give you a UI to access the log files?
Autodesk Fusion
Join Fusion Insider
Message 18 of 31
Here's the log file and my software in Chinese it basically means it's not sure what's stopping to install.
Message 19 of 31
RajkumarIlanchelian
@Anonymous We are still looking at the log files and trying to understand what is blocking you from installing.
Requesting one more information - Can you please run this - ls -ale@ /Users/n/Applications in the terminal and report back the information that you see?
Autodesk Fusion
Join Fusion Insider
Message 20 of 31
It says command not found if i type this in (ls -ale@ /Users/n/Applications ). Did I put the right thing in?
