I'm really stumped. I can't get this sketch to extrude. Prior versions based on an imported sketch would extrude, but the draft command invariably failed. So, I traced the outline manually with lines and splines and deleted the imported version. Now I can't select anything but individual line segments. Even trying divide and conquer, as suggested in a prior such posting, reveals nothing. The new line just sits there with no faces appearing. Thanks for any assistance.
Solved by TheCADWhisperer. Go to Solution.
First I deleted a "floater" an arc wayyy out in space.
Then I used the divide and conquer technique to find an issue between the i and t at the top loop.
Also upper left of K.
Fixed that and all is well. (BTW - you have a lot of white dots at endpoints that should be connected.)
Oops, I still have an error I need to find.
That is so AWESOME! Thanks a million times over. Sorry for delayed response. My computer started choking on Fusion when I tried to close out the file. Two registry cleans and two reinstalls later I can finally appreciate what you did. I know I have lots of white dots, and that's after scrubbing the design to get rid of them. BTW, what were the issues you found?
