I am trying to find my Fusion360 projects from the web browser. I did that in the past, but now it seems that something changed???
I am trying to access the projects since one hour…but no success yet.
This
https://www.solidsmack.com/cad/fusion-team-access-fusion-360-browser/
seems to be obsolete…
When I log in “Fusion Team” does not exist anymore, there you find “account settings”. Going there will bring you to your account setting…. But from there you cannot access your project.
By the way, I find counterintuitive the fact, after log in and going to your member area there is no link to your files. You can only switch between your profile and your account settings.
Can somebody help me?
Alex
Solved by paul.clauss. Go to Solution.
Thanks for posting! That article is mostly current, but I've shown how I access my data in the screencast below.
I think that article is a little outdated - the site shows "Fusion Team" rather than "A360" for me now. It may also help to clear your browser cache or try accessing your hub in an Incognito/Private Browsing window.
I also usually navigate using the direct URL: myhub.autodesk360.com.
I hope this helps! Please let me know if you have any questions.
Dear Paul,
thanks a lot for your help!
The solution - myhub.autodesk360.com - was exactly what I was looking for.
Nevertheless, the other solution option shown by your screencast does not work, simply because “Fusion Team Button” is not there, see my screenshot. https://ibb.co/d6Rz09
Alex
Hi @hilgenbergalex,
thanks for posting. I cannot see the URL of the website you are trying to access it from, but it's not available from any random Autodesk site.
I can see it when I go to https://www.autodesk.com/products/fusion-360/overview# - let me know if it's still missing for you when you go to that site.
However, I myself never use this button - it basically directs you to myhub.autodesk360.com that @paul.clauss mentioned.
Best regards,
