Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Can you change the failure criteria used to present results in your simulations?
3 REPLIES 3
ammosfilms44
176 Views, 3 Replies
Hey! I am working on modeling some concrete structures, which has a high compressive strength and low tensile strength. With that, the Von Mises criteria is used for materials that doesn't have asymmetric properties like concrete. With that, I am using Coulomb-Mohr's to evaluate the factor of safety of these structures. Is there a way to change my results to show stress for my static load case in Coulomb-Mohr's instead of Von Mises?
3 REPLIES 3
henderh
in reply to: ammosfilms44
Hi @ammosfilms44,
The Safety Factor results are based only on Von Mises yield criterion.
I'll check if we have an improvement logged to add Coulomb-Mohr, Tresca, etc. and report back.
Best regards,
Hugh Henderson
QA Engineer (Fusion Simulation)
henderh
Hi @ammosfilms44,
I've added Coulomb-Mohr results display as a feature request (FUS-158524) with reference to this forum thread.
Thank you for bringing this to our attention.
Hugh Henderson
ammosfilms44
in reply to: henderh
Thank you!!
