Can you add joint origins in an assembly or do they need to be put in at the component level?
I thought you used to be able to..
Solved by jeff_strater. Go to Solution.
Assuming you mean:
then, the answer is "no" - you cannot add these at the assembly level - they have to be in the component's design. At the moment, Joint Origins cannot even be added during Edit in Place, although I expect that to be added at some point.
