I've downloaded Fusion 360 today as a student license but can't see a way to render my object. Looking at the Forums it seems that I need credits, but none are available.
Is there anyway you can help?
Many thanks
Seren
Have you checked here under your Preferences in Fusion 360?
John Hackney, Retired
Hi @Anonymous
If you go to http://manage.autodesk.com/ does it say student under Fusion 360?
If not then you will need to sign up for an edu account >>HERE<<
If you do then:
Failing that contact education support: https://www.autodesk.com/education/support
