Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Can´t use orbit
24 REPLIES 24
Message 1 of 25
tomjansson909
5087 Views, 24 Replies
Can´t use orbit
Can´t use orbit or any other button in the bar down in the center after last update.
24 REPLIES 24
Message 2 of 25
Phil.E
in reply to: tomjansson909
Please try restarting Fusion and if that doesn't help, restart your computer.
Phil Eichmiller
Software Engineer
Quality Assurance
Message 3 of 25
tomjansson909
in reply to: Phil.E
Thanks Phil . I tried that a couple of times with no luck. But i continued using the program and suddenly it start work again.
Message 4 of 25
Any update on this issue?  I still run into this problem quite frequently.  Is "keep restarting until it works" the plan of record solution?
Message 5 of 25
Phil.E
@Anonymous  Thanks for asking. Restarting Fusion should not be the only solution here. Unfortunately, "orbit" is achieved using at least 5 different methods, so it might help to explore your particular situation and not assume it's the same issue as the other person posting on this thread.
  • What kind of mouse are you using?
  • What is your operating system?
  • With what method do you use Orbit?
Phil Eichmiller
Software Engineer
Quality Assurance
Message 6 of 25
in reply to: Phil.E
Hi Greg,
My mouse is a Logitech M705. Windows 10 with all the regulaly scheduled updates. I'm typically doing "Constrained Orbit" by clikcing the orbut button on toolbar that floats near the bottom of the design view. Usually this works fine, but sometimes none the buttons in said tool bar respond to clicks. Sometimes closing and restarting Fusion 360 fixes things, but sometimes it does not. Once the toolbar works, it works for the entire time I have Fusion open. The problem only manifests itself when I first open my design from a new Fusion session.
One thing I want to try is to first attemp to use Orbit using the bottom toolbar in the default blank design that opens by default with Fusion starts before I open my design. Perhaps there's something in my design file thats and how it loads that is causing grief? Other than that, I want to explore alternative ways to access all the tools in that toolbar and get out of the habit of using the toolbar at all..
Thanks for you attention,
Clay
Message 7 of 25
Phil.E
Thanks for the details.
I can't say I've seen exactly what you describe, but the only problem I've ever had with my own logitech mouse is fading batteries. When only some clicks start to fail I always change the batteries and the problem goes away.
There are drivers for your mouse, make sure you have the latest.
It might also be necessary to update your graphics drivers, let me know if you need help with that. Do not use the Windows update tool, it can sometimes show no problem when really drivers are out of date significantly. Try the manufacturer driver page for your video card.
Regarding navigation in Fusion, and methods to orbit/pan/zoom:
  • The best way to do navigation is using the mouse and keyboard buttons/shortcuts.
  • There are several distinct modes of navigation. These are selectable and graphically explained in the Quick Setup guide. Look on the ?Help menu for Quick Setup.
Here is my favorite method, Tinkercad mode. It places all navigation on your mouse with no additional keyboard hotkeys required.
The only other concern I have is that you report the navigation bar becoming unresponsive, which is not a typical complaint. Of course if we can reproduce that bug it's possible to debug it and fix it in the code. Please let me know if that problem continues after all the updates and steps above. Glad to look deeper into whatever is causing that.
Good luck, best regards,
Phil Eichmiller
Software Engineer
Quality Assurance
Message 8 of 25
in reply to: Phil.E
Thanks @Phil.E.  Sorry for the late response.  I tried Tinkercad mode and like it. I have yet to acquire a taste for the "Marking Menu" and much prefer the right mouse button for orbit.
I still get the unresponsive navigation bar from time to time (Fusion version 2.0.10148), but now it looks like I can resolve the problem by just closing the re-opening the design rather than having to completely shut down Fusion.
It's not really reproducible.  I could send you a pointer to my design but who knows if you'll see the behavior on your end.
Message 9 of 25
As of today, I am also having problem with orbiting ... I have been using Fusion 360 for over a year and have had no change of behaviour with orbiting and now I can only do it with the cube at the top right.
I did change my PC but that was 9 months ago and I have not changed any hardware since.
I have updated all drivers and no other software is affected
Message 10 of 25
tomjansson909
I bought a spacemouse and never had the same problem again. And i can really recommend it even without that problem. I use to get hurt in the arm before after 5-6hours/day and a lot of the movement change to left hand so it helps a lot.
Message 11 of 25
Thanks for your reply though for some reason it started to work again all of a sudden !  so frustrating !
I had a look at the spacemouse and it looks very good ... but unfortunately it's outside my price range 😞
Message 12 of 25
chip7C54M
Im having the the same problem. Orbit will stop working after using fusion for a few minutes. Cant orbit with the mouse, (right click via tinker mode or by selecting the orbit button from the bottom menu). Nor will it orbit or change view by clicking the ortho cube in the upper corner. Super frustrating. Ive tried restarting fusion and my computer. but i loose the orbit ability within the first ten minutes of use each time after the reboot.
Im running a 2021 macbook pro. ironically I did not have this problem on my 2012 macbook. fusion has been freshly re-installed.
Message 13 of 25
Phil.E
in reply to: chip7C54M
This is not a commonly reported issue.
What sort of mouse are you using? Extra monitors?
Do the named views continue to function after the view cube and orbit command have failed?
Phil Eichmiller
Software Engineer
Quality Assurance
Message 14 of 25
chip7C54M
in reply to: Phil.E
Hey Phil,
Thanks so much for your help! Im using a logitech mouse, but I also tried it just using the tack pad, and Im just using the laptop screen. Ultimately I discovered it was related to the operation I was performing (a multiple plane sketch). when I modeled the part a different way I no longer had the problem.
Message 15 of 25
chip7C54M
in reply to: Phil.E
Hey Phil,
Do you have a mouse recommendation?  After playing around some more I think that may have been the culprit.
Message 16 of 25
Phil.E
I'm a bit of a weirdo when it comes to hardware. I prefer rock-solid, dirt-cheap, dead-simple gear. So my recommendation is only personal. I use a logitech M100 mouse.
Phil Eichmiller
Software Engineer
Quality Assurance
Message 17 of 25
xh11jab
in reply to: Phil.E
Sorry to Chime in, but this is my problem, My SpaceMouse works perfect on Fusion, say when I'm doing a Press Pull, then as soon as I hit enter or finish that task or finish sketch, suddenly my movement is limited, and I can't do the majority of Spacemouse movements. However, when I use the cube in the top right hand corner, or the actual 'orbit' button at the bottom right above the timeline, they work as expected.
This happens multiple times, so far, I've determined that it always works when I'm in the middle of a press pull, and never works as soon as I complete the press pull function.
Message 18 of 25
Phil.E
in reply to: xh11jab
What model of spacemouse do you have and what version of the drivers are you using?
Phil Eichmiller
Software Engineer
Quality Assurance
Message 19 of 25
xh11jab
in reply to: Phil.E
So I have a now discontinued SpaceNavigator (3DX-600028) but I'm also using a new/current model CADmouse Compact (3DX-600068)
I believe I am using the latest driver version (3DxWare64_v10-8-7_r3448)
Message 20 of 25
Phil.E
Have you applied the legacy spacemouse drivers in preferences?
If prompted to restart after making a preference change, do not use the prompt to do so. Close the preference dialog (after committing the change), wait 30 seconds, then manually close down and restart Fusion.
Does this help?
Phil Eichmiller
Software Engineer
Quality Assurance
