Can't stop displaying wire frame
Hey folks,
For the life of me, Fusion 360 started displaying in this weird wire frame format, picture attached.
How do I get rid of this and get it back to displaying solids? I'm new to 360, so I'm totally lost as to how I even changed this preference, but it was showing solids just yesterday...
jeff_strater
first thing to try:  set your Visual Style to "Shaded with visible edges only" using the settings widget at the bottom of the screen:
As you can see, there is a hotkey for this command (on Mac it is CTRL-4 through CTRL-9).  It's possible that you accidentally hit some ctrl-key combo to change the style
Jeff Strater
Engineering Director
That was it, thanks!
thats what I get for mashing keys to see what shortcuts do what. Mastercam uses a modifier/number combination to see certain views, I think I tried that here.
alisleimanchehade
Community Visitor
Community Visitor
I have the same issue but it’s a bit different and it sooo annoying and can’t seem to find a fix for it!
my settings are exactly as the answer provided to you but it keeps going into wireframe every time I press on the mouse wheel then it goes back to a solid! How the hell do I stop it going into wireframe each time I move and rotate my model?!?!
please anyone help me 🙏🙏🙏
g-andresen
then I would check the mouse settings and possibly try a different mouse.
günther
alisleimanchehade
Community Visitor
Community Visitor
Thank for the quick reply 🙏 but it wasn’t the mouse. I went into preferences and reset all settings to default and it went back to normal guess I did something wrong inside the the settings and I have totally forgot that I even changed anything in there 😅
anyway thanks again man truly appreciate it 🙏🙏🙏
