I have just started using templates in fusion . I have added several copies of the same operation. Now I want clean these up. I choose select template , I can't see the templates. I have attached a couple of screenshots to show what I see. I have looked every where for them. I can pick them from the first drop down, but I can't delete them there. Ok I'm ready to fill stupid, What am I missing ?
Solved by AmandaFowler. Go to Solution.
Hi there @jerrybentley
Thanks for posting! Looks like those templates are stored on the cloud. Check your data panel for the Assets folder under Libraries (or your personal hub at https://a360.autodesk.com/ with your Fusion 360 login credentials) and they should be stored in the CAMTemplates folder. You should be able to delete them from there.
Let me know if that helps you out!
I just wanted to follow up with you on this - did my last post help you out or do you still have questions?
Thanks!
Thanks!
No problem! Thanks for letting us know - I'm glad that was all it is so that you can get back to making things 🙂
