Can't loft body
nectarietotan
Can't loft body
nectarietotan
Hi! I have a problem, I want to loft a body, it's quite complex, but I can't, I keep getting errors.
I will post photos of the object I want to model, but it's not the same, I have other dimensions because I want to make it more compact.
Replies (10)
davebYYPCU
Not enough control of the shape in those sketches.
Make a sketch on ZY Plane, connect the shape at this location  using Project > Intersect for the 4 points to connect to.
When you do that, still won’t work, because 2 sketches have sharp points.
Circle can’t loft to the horizontal sketch, if the corner is aligning with the same plane.
Use Surface Loft, and small sections at a time.
Might help….
TrippyLighting
How's this for a start?
That's very nice looking, like what I wanted, how did you do this?
I attached a model to my last post. If you step through the timeline, you should be able to see how this was modeled.
nectarietotan
Thank you for your help till this point, I still have a problem, I tried @TrippyLighting method using the timeline from the 3d model he provided, and it worked, but I don't get an exactly nice shape when doing the fillet, I don't quite get continuation for the first face/profile. I divided the upper body by the second face/profile and then tried to loft the upper section of the first face/profile and the newly divided section, but the loft is not nicely executed.....What should I do?
@nectarietotan wrote:
What should I do?
Share your model.
The screenshots indicate that you did not understand or follow the workflow in my model 😉
Here is the model.
Your model does not have a timeline, which does not allow me to reproduce your workflow.
The sketch inputs you have created don't lend themselves to a fillet.
I used a surface modeling approach and simply had to guess what you're after.
If you want to actually make a physical artifact, then would strongly recommend that you use a caliper to measure key dimensions and then fully constrain and dimension your sketches!
2025-01-13 15-22-52.mp4
Video Player is loading.
Current Time 0:00
Duration 2:49
Loaded: 5.84%
Stream Type LIVE
Remaining Time 2:49
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    Edit: I've replaced the attached model with one that has a timeline 😉
    nectarietotan
    Thank you so much! I didn't know I could use surface modelling, I only worked with solid, you did exactly what I wanted to do!
    Type a product name
    ______
    icon-svg-close-thick
    Cookie preferences
    THIRD PARTY SERVICES
    icon-svg-hide-thick
    icon-svg-show-thick
    Qualtrics
    Akamai mPulse
    Digital River
    Dynatrace
    Khoros
    Launch Darkly
    New Relic
    Salesforce Live Agent
    Wistia
    Tealium
    Upsellit
    CJ Affiliates
    Commission Factory
    Typepad Stats
    Geo Targetly
    SpeedCurve
    Qualified
    icon-svg-hide-thick
    icon-svg-show-thick
    Google Optimize
    ClickTale
    OneSignal
    Optimizely
    Amplitude
    Snowplow
    UserVoice
    Clearbit
    YouTube
    icon-svg-hide-thick
    icon-svg-show-thick
    Adobe Analytics
    AdWords
    Marketo
    Doubleclick
    HubSpot
    Twitter
    Facebook
    LinkedIn
    Yahoo! Japan
    Naver
    Quantcast
    Call Tracking
    Wunderkind
    ADC Media
    AgrantSEM
    Bidtellect
    Bing
    G2Crowd
    NMPI Display
    VK
    Adobe Target
    Trendkite
    Hotjar
    6 Sense
    Terminus
    StackAdapt
    The Trade Desk
    RollWorks
    Your experience. Your choice.
