Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Can't insert components as link after Fusion Hub update
2 REPLIES 2
Sebastian_Galo
128 Views, 2 Replies
Hi!
I updated my Fusion install today and now it seems to be a bug or something. I can't insert components into an assembly as a linked component (as usual), Fusion wants to make a copy instead. All the components and assembly are placed in the same folder and in the same hub as far as I understand it.
Anyone else got this problem? Am I missing something? See attached screenshot.
Thanks!
Labels (4)
2 REPLIES 2
You did not show, in your screen capture, your current Hub.  From the error message your workspace design in not located in the same Hub of the components you are trying to insert.  At the top of your Data Panel, verify the current Hub your are working in  and the Hub the inserted components are in.
John Hackney, Retired
Thanks for your answer! I only got one hub and its a Team hub with my name. I'm admin and I have not worked with Hubs in any way before. It's a Personal Non Commercial subscription. This became an issue after an update. So my guess is that fusion did some kind of file transfer or changed hubs from personal to team, but my files are stuck in some kind of limbo?
Check the attached files.
