Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
can't delete tangent constraint and apply to different geometry
1 REPLY 1
Noah_Katz
800 Views, 1 Reply
I accidentally "missed" and applied tangent constraints to the wrong arcs.
I deleted and tried to apply to the right one, but get a solve error, as shown in the screencast.
This happens a lot as I fuss with this belt grinder design; I've taken to just deleting the lines and making new ones.
Solver bug?
Design: http://a360.co/2v4O0UT
1 REPLY 1
innovatenate
in reply to: Noah_Katz
I think you might be missing one small step. There are really two constraints to deal with here. One is a tangent constraint and one is a coincident constraint for the endpoint of the line.
Before applying the new tangent constraint:
  1. Delete the old tangent constraint
  2. Select the endpoint of the line
  3. Select the Delete Coincident command from the right click menu
  4. Then add the tangent constraint
I hope that  helps. Let me know if you have any questions.
Nathan Chandler
Principal Specialist
