Can't change units of first user parameter created
I just found out the hard way that I can't change the units of the first user parameter I created. Unfortunately, I simultaneously found out the hard way that some formulas cannot use parameters that contain units. A double-whammy!
I can change the units of every other user parameter I create. Of course, if I could change the order of the parameters, I wouldn't actually care about the above two issue(s). But I can't, so triple-whammy!
Please make the first user formula created have editable units.
Also, why can some formulas use parameters with units and some can't? It's weird! I have parameters that include formulas with other parameters with units, but when calculating an angle with ARCTAN, it would not accept any of these same parameters.
It wouldn't be a problem if I could create a unitless version of a parameter that references the other parameter, but Fusion won't let me do that.
I attached a file for fun.
