Fusion Support
Can orbit or pan using mouse.
6 REPLIES 6
adamswg
517 Views, 6 Replies
adamswg
The orbit and pan don't function sometimes when I launch Fusion 360.  Sometimes I can restart the program and it goes away and sometimes I have to reset the preference.  I am running Fusion 360 on OSX.  At first I thought it might be my trackpad or mouse, but eventually was able to reset the interface to get them working.  My mouse and track pads are working perfectly as far as I can tell.  I am not quite sure when this started, but it may have been when I tried the new tool menu.  The new tool menu simply disappeared today and also reset my interface.  Lots of strange behavior.
6 REPLIES 6
karina.harper
in reply to: adamswg
karina.harper
Autodesk Support
Autodesk Support
Hi @adamswg
Have you tried performing a clean uninstall? That might do the trick.
Let me know,
Karina
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
Hi @adamswg
Let me know,
Karina
Karina Harper
adamswg
in reply to: karina.harper
adamswg
I tried uninstalling and reinstalling without any improvement.  The orbit and pan do not work at all.  😞
adamswg
adamswg
Tried several things and couldn't get it to work.  Then rebooted my machine and after a bunch of lag it started working again.  Very strange behavior.
karina.harper
karina.harper
Autodesk Support
Autodesk Support
@adamswg
Is it currently working now?
Cheers,
Karina
Karina Harper
@adamswg
Cheers,
Karina
Karina Harper
adamswg
adamswg
It is working now, but this has been an intermittent problem.
adamswg
adamswg
I've been traveling and have not used Fusion 360 for a few months.  Just got in to design some things today and am having this exact same issue.  The orbit and pan do not work again.  Very disappointing, because productivity drops to near zero without these shortcuts.  Also the pan function works more like a zoom on steroids, so instead of panning it zooms way out very quickly.  Not sure how I managed to fix this last time, guess I'll just poke around until I can get it to work again.
