can I somehow add an extra 3d print utility?
MortenGuldager
MortenGuldager
I often send designs to different 3d print utilities, to name a few: cura, prusa slicer, and formlabs.
Question is if I can add these to the drop-down menu in the 3d-print menu in f360?
/mogul
tomHJB4M
Yes you can!
In the dropdown you can pick the custom tab and browse to the .exe file of your 3d printer software.
In the example below i used Raise3d their software Ideamaker, which works as intended.
JeromeBriot
@MortenGuldager @tomHJB4M You can try the 3D Print Plus add-in that supports many 3D print utilities:
