Can I save a new version of a model and also keep a new version of an associated drawing?
kevin399ML
kevin399ML
I have multiple parts that are nearly identical except for one dimension. I have modeled the first and created a fully dimensioned drawing. Is there a way to make the a change the model, save it with a new name and also keep a new version of the drawing without having to regenerate the new drawing from scratch? The only way I can get the drawing to update is to save over the original model using the original file name. I could start playing tricks by saving a copy to another location and then over-saving the original, but even if I do something like this, both versions of the drawing remain linked to the same model.
Is there anything I am missing, or do I just need to generate each version of the drawing from scratch? Sorry if this is already in the boards, but I had no idea what to search for to find this.
thanks
Kevin
ClintBrown3D
Hi @kevin399ML
If you view the drawing online, you can then download a Fusion Archive.
Click the Download icon, then Choose Fusion Archive. You'll be emailed a link to download.
If you upload this F3D, you will have a separate model and drawing that are linked, so you can now make edits without it affecting anything else.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
kevin399ML
Thank you Clint! I have been trying to figure this out, but I am still not getting this to work. If I start from the model, I can follow the steps you laid out, but when I upload the .f3d file back into fusion I just have the model and not the drawing. If I start with the drawing, the file I get is .f3z and I am not able to get fusion to open this file.
ClintBrown3D
Hey @kevin399ML
If you upload the F3Z, this is a packaged Zip file that contains the drawing and the model. Once the F3Z file is uploaded, Fusion will unzip it and make a drawing and model available, it will take a couple of minutes.
Clint Brown
kevin399ML
Got it. I was trying to open it rather than upload it. Thank you very much for the assistance!
