Fusion Support
[Bug] Text height parameter is negative in "old" document
1 REPLY 1
thomasa88
286 Views, 1 Reply
The value of Text1-Height is negative in the attached f3d. The value should be 8 mm, as seen by inspecting the text. (This breaks my script, when it's trying to correct for the SketchText.height bug).
The document was created before text height parameters existed.
Note: When I exported my document and saved it as f3d, I did not first see Text1-Height after opening it. However, the value is still there, as scripts still pick it up from allParameters.
Workaround, to restore the correct value: Edit the sketch text manually to correct the parameter. Nothing needs to be done. Just Edit the text, confirm that the height is correct and press Ok.
ParametricText add-in issue reference: https://github.com/thomasa88/ParametricText/issues/24
121575146-51369900-ca27-11eb-80c3-99ba5d9ee587
1 REPLY 1
Rohan.bongale
in reply to: thomasa88
Thank you for addressing the issue. I am able to reproduce this issue at my end. I have logged a bug and addressed it to the development team to have a look.
Thank you,
Best Regards
Rohan Bongale
| Senior QA Engineer  | Autodesk India Pvt Ltd.
rohan.bongale@autodesk.com|
