Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Bug Report: Dimensions calculate incorrectly on broken view
3 REPLIES 3
thecustomcab
160 Views, 3 Replies
Hello - I noticed what I think is a bug in Fusion's dimension handling in the Drawing space:
I created a broken view of a tall object, and found that dimensions were incorrectly calculated. Here are two screen caps of the same object, with ordinate dimensions shown, one with a broken view and the other without. Linear dimensions produce the same incorrect result.
Is this expected behavior?
Chiliarch
3 REPLIES 3
jhackney1972
in reply to: thecustomcab
You used the "Center Mark Pattern" command to place the center marks on the holes.  If you go back and use the "Center Mark" tool and stretch the center marks to join them together, the Broken View dimensions will work correctly.  The "Center Mark Pattern" command is causing the error and it has been broken for awhile@ClintBrown3D Please note this a something to look at.
John Hackney, Retired
thecustomcab
John, Thanks for the quick reply! This is a great workaround until the bug is fixed. Thanks in advance also to the Fusion team for looking into the underlying problem.
C
liang_chen
This is a known issue and tracked as FDWG-14817. We are working on it. Thanks
Fred Chen
SQA Engineer
Quality Assurance Team
