Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Bug / Rendering: "Focal length" setting changes and is not shown correct after "Fit" pressed
2 REPLIES 2
mkirstein
217 Views, 2 Replies
Reproduce:
Go to rendering.
Open Scene settings.
Set "Focal Length" to a value like 200 mm.
Push "Fit" (Fit to screen) button at the lower area of the scene.
"Focal Length" is now set to 90 mm but still shows 200 mm.
When moving the bar a little, the model hops to 200 mm back.
The problem does not occur while having the "Scene settings" closed, pushing "Fit". But the value is still changed to 90 mm.
I don't know what would be the preferred behaviour:
1) "Fit" fits the model into the scene and leaves the "Focal length" untouched. (preferred by me)
2) "Fit" fits the model into the scene and changes the "Focal length" to 90 mm.
But the fact that a wrong value is displayed generated a lot of additional work for me.
Labels (4)
2 REPLIES 2
Phil.E
in reply to: mkirstein
Thanks for the detailed report. Now logged as a bug (ref: FUS-119069)
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Phil.E
Sorry for the delay in letting you know that this issue was addressed in the recent update in July. Thanks for letting us know about it.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Technology Administrators
