Announcements
Bug: No way back after "file not found"
andypugh
Message 1 of 11
andypugh
Fusion Mac. I just tried to share a link to a model in my data pane, and got this dialog box. Which can't be closed, and leaves Fusion unresponsive (It is not even possible to quit Fusion, I needed to force-quit it from the OS)
(I am not sure _why_ it said that the file could not be found, it was there in the data pane, and the file opened without issues after I restarted Fusion)
Replies (10)
Message 2 of 11
rishabh.bisht
@andypugh
I am sorry about the issue you faced.
Are you still able to reproduce it? If you are able to consistently reproduce it, could you please record and share a video? It would help us reproduce and diagnose the issue at our end.
Thanks!
Rishabh Bisht
Product Owner
Message 3 of 11
andypugh
I haven't had the problem re-occur.
But a video wouldn't show much. One click on the data pane, then a dialog box with no exit button. Then a force restart of Fusion.
Message 4 of 11
rishabh.bisht
Hi @andypugh ,
Good to know that it was a one-off case. Please feel free to report back if you are able to see this issue again.
Thanks!
Rishabh Bisht
Product Owner
Message 5 of 11
andypugh
Well, it happened again.
Much the same. I saved the design, then right-clicked in the data pane on the design to create a sharing link.
The file does exist. After restarting Fusion I created a working link with exactly the same workflow.
I remembered that you were keen to see video, but wasn't prescient enough to start the video before the problem occurred. But please beleive me when I say that only one right mouse click is missing.
My previous statement that I had to force-quit Fusion was false. The Fusion main window is completely unresponsive, but I was still able to quit Fusion from the main menu. (On MacOS the menu is not part of the main window)
It seems to me that the fix should start with idenitifying the dialog box that is raised, and then working out why it can;t be closed or acknowledged.
Message 6 of 11
rishabh.bisht
Hi @andypugh ,
Could you please share your Web Services and App log file?
You can find the instructions to collect logs here: https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
Thanks!
Rishabh Bisht
Product Owner
Message 7 of 11
andypugh
You mean just attach the ZIP file?
Message 8 of 11
rishabh.bisht
Thanks for sharing the log files. I will take a look at them.
Do you by any chance recall when you faced the issue (Date and approx. time)? It can help me narrow down the logs I need to scan through.
Were you able to reproduce it again after the second time?
Rishabh Bisht
Product Owner
Message 9 of 11
andypugh
The last time was a few minutes prior to my previous error report. (GMT+0 London timezone)
Message 10 of 11
andypugh
This still happens, a few weeks ago, and just now.
I am a hobby user, this correlates to being about 50% of the time that I attempt to share a link.
Message 11 of 11
andypugh
The behaviour here has changed, but isn't better.
