Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
[BUG] Joint origin does not take parameters the first time.
6 REPLIES 6
TrippyLighting
486 Views, 6 Replies
Yep, I know this has been reported a number of times including by your's sincerely.
It is tiring and frustrating having to do this over and over again!
I was trying to use a dimension (d3, the diameter of the pipe feature) as a parameter in the joint origin dialogue so it would always be in the correct spot when that diameter changed. No such luck. the dialogue only converts the parameters into a numerical value when placed into the floating fields.
Wen placed into the UI window files that also has to be done twice.
Can I get this to work ? Of course.
How do I explain this to an excited Fusion 360 newcomer ?
This is not rocket science!
6 REPLIES 6
Hi @TrippyLighting
Can you clarify this as a screencast?
From what I understood, I wasn't able to reproduce. d1 worked as an entry in the modeling window for me.
Cheers,
Karina
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
@TrippyLighting , I was all set to believe you, because I know that there are still places in Fusion where the equation is not captured.  So, I found the original bugs on this (FUS-21005 and a duplicate FUS-30219), which reference forum thread litte-joint-origin-ui-bug.  But, those bugs have been marked closed as of Dec 2018.  So, I just tried this out for Joint Origin, and it seems to be working OK.  So, maybe your workflow is a bit different than mine, if so, a screencast would help.
Jeff Strater
Engineering Director
For a moment I thought I am starting to loose my mind but I did a bit more diggin'
Edit the joint origin and you shall see (insert evil laughter).
Ah, OK, Edit Joint Origin.  Got it.  Bug is filed as FUS-47947
Jeff Strater
jeff_strater
in reply to: jeff_strater
follow-up:  This bug has now been fixed in the current production build
Jeff Strater
Great! Thanks for the feedback!
