ご存知の方がいらっしゃいましたら、ご教示下さいませ。
シートメタルの「展開」から「再折り曲げ」の間にボディを作成したのですが、
途中から、ゴースト表示になり薄くて見えにくく困っています。
①初期設定に不備?
➁根本的に作り方が違う?
何卒、宜しくお願い致します。
009b288e-813d-43ec-ab47-931d248435bd,640,590
Solved by jhackney1972. Go to Solution.
My guess, as the best I can translate with Google Translate, is that you have switched your display to Wireframe or Wireframe with Hidden Edges. Set the Visual Style back to Shaded or Shaded with Visible Edges.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Thank you so much.
I switched the visual style, but the body remained opaque.
https://autode.sk/2s1oGAm
By setting "Body → Control of opacity → 100%", it was possible to display.
https://autode.sk/37CJ6i5
Solved. Thank you.
