I am doing my first project in FUSION 360 during the rendering the window close automatically
what would be an reason? its happen continuously
help me to solve this issue
and I add screencast to show when it's closing
Solved by salaimanimagudam. Go to Solution.
Solved by masa.minohara. Go to Solution.
Thank you for posting in the community forum! That is a known issue and a workaround can be found in this page. Could you try that and let me know if that helps?
Please let me know if you have any questions!
superb it's working @masa.minohara
but what reason behind that ? its only works for english(us) even I change any other it doesn't work
Thank you for the update! Glad to hear it worked. Unfortunately that is a bug in the latest version of Fusion 360 and I apologize for that.
The development team has fixed the program and now they are preparing to release a hotfix. Once you install hotfix, the issue won't occur with your original system locale.
@masa.minoharathanks and I dId first project
