Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Automatic update failed.
2 REPLIES 2
wh6Q9NU
605 Views, 2 Replies
Restart OS won't solve update error.
Any suggestions welcome!
2019-11-16 13:42:40,201 - MainProcess(567) - Dummy-1 - adsk.dls.streamer.process - ERROR :: Exception during processing:
Traceback (most recent call last):
  File "nspylib.zip/process.py", line 1539, in execute
File "/Users/xxxxxxx/Library/Application Support/Autodesk/webdeploy/production/0595b76b5846e142c8ccd553d74593b1121ccc51/Autodesk Fusion 360.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/codecs.py", line 322, in decode
    (result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xff in position 0: invalid start byte
2 REPLIES 2
Exactly the same here...maybe a central problem ?
wh6Q9NU
in reply to: wh6Q9NU
Removed and reinstalled Fusion 360 as described here:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
and Fusion360 works again.
Hopefully this was a one-time-only re-installation.
