Autodesk Folder missing from application support on mac
ajeff22209
Message 1 of 10
ajeff22209
The folder titled "Autodesk" in the application is not visible/in my computer. I can't find it anywhere so I can't install and addins. I tried searching it up and I found 2 other folders but not with the subfolders it's supposed to have. I've tried re-installing, the only other option I can think of is resetting my Mac and I really don't want to do that.
Replies (9)
Message 2 of 10
RajkumarIlanchelian
@ajeff22209 Fusion has a different install than other Mac apps. You will find the folders in Application Support.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 10
ajeff22209
its not there, it doenst seem to be on my computer at all. I cant find the folders that are supposed to be there as well
Message 4 of 10
RajkumarIlanchelian
@ajeff22209
1. Go to Finder
2. Then click on GO - then click on the "option" button the the keyboard
3. This should now show the "library" option in the Go list.
4. In there when you click on Application Support are you able to see the Autodesk folder?
If no, then go to go into launchpad and show me what you see from Fusion in there?
Autodesk Fusion
Join Fusion Insider
Message 5 of 10
ajeff22209
I'm not sure what you mean when you say "GO" in Finder but when I do the file path of Macintosh HD-Library-Application support, there is no Autodesk folder. Also, what do you need in Launchpad? is the attached file what you need?IMG_2271.png
Message 6 of 10
RajkumarIlanchelian
@ajeff22209 So go to
Macintosh HD/users/usersID/Library/Application Support.
Autodesk Fusion
Join Fusion Insider
Message 7 of 10
ajeff22209
Ohhhhhhhhh, thank you!
Message 8 of 10
ajeff22209
Would you know how to set up the haas driver add-in, it doesn't work
Message 9 of 10
RajkumarIlanchelian
@ajeff22209 I can certainly ask the respective engineering team to connect but it would be easier to post in https://forums.autodesk.com/t5/fusion-manufacture/bd-p/2070 and call put as help to install hass in the title.
Autodesk Fusion
Join Fusion Insider
Message 10 of 10
ajeff22209
ok, Thank you very much for your help!
