Bug Report: cannot upload Fusion files to Gallery
OceanHydroAU
Message 1 of 1
OceanHydroAU
We can select *.f3d files, however, the javascript on the web page blocks them:
https://www.autodesk.com/community/gallery/
Please ask your web team to fix their JavaScript.  These are the file types the HTML allows us to select:-
accept="image/jpeg, image/jpg, image/png, image/gif, .f3d, .ipt, .f3z, .3dm, .3ds, .asm, .catpart, .catproduct, .cgr, .collaboration, .dae, .ddx, .ddz, .dgk, .dwf, .dwfx, image/vnd.dwg, .dwg, .dwt, .fbrd, .fbx, .fsch, .gbxml, .glb, .gltf, .idw, .ifc, .iges, model/iges, .igs, .ipt, .iwm, .jt, .max, .neu, .nwc, .nwd, .obj, application/x-tgif, .osb, .par, .pmlprjz, .prt, .psm, .psmodel, .sab, .sat, .sch, .skp, .sldasm, .sldprt, .smb, .smt, .step, .stl, model/stl, .stp, .vpb, .vue, .wire, .x_b, .x_t" class="sc-bDunJF hzJLEl"
The problem seems to be a complex scripting issue, because your javascript ( https://www.autodesk.com/static/js/main.bdfb5dad.js ) looks like it's supposed to allows us to upload:
allowedFiles: ".jpeg, .jpg, .png, .gif, .f3d, .ipt, .f3z, .3dm, .3ds, .asm, .catpart, .catproduct, .cgr, .collaboration, .dae, .ddx, .ddz, .dgk, .dwf,.dwfx, .dwg, .dwt, .fbrd, .fbx, .fsch, .gbxml, .glb, .gltf, .idw, .ifc, .iges,.igs, .ipt, .iwm, .jt, .max, .neu, .nwc, .nwd, .obj, .osb, .par, .pmlprjz, .prt,.psm, .psmodel, .sab, .sat, .sch, .skp, .sldasm, .sldprt, .smb, .smt, .step,.stl, .stp, .vpb, .vue, .wire, .x_b, .x_t"
but something is triggering it to block by mistake:-
This is the file by the way it is also attached to this bug report):
https://a360.co/3xVL3ZL
Replies (0)
