Fusion 360 recently has implemented an auto grouping feature. When I create a sub-component it always comes grouped to the parent component automatically. I then usually have to break the grouping. How do I disable auto-grouping?
Solved by mayank.malukani. Go to Solution.
If you create a component it falls under the component that is Active unless you select another in the Create Component dialog box. If this is not what you mean, please attach a screen capture or model to demonstrate you issue.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Hi @simonjohnlacey ,
If you don’t want your components to be ground to parent automatically, you can change this default behavior. In the top-right corner, on the Application bar, click your Avatar and select Preferences. From the menu on the left, expand Design and select Assemblies. Uncheck "First component grounded to parent.
