hallo !
i am an Hobbyist.
i am using Fusion 360 on a free of charge base.
i am using Fusion 360 in german language.
may be it is necessary to you to know this.
my Trouble is: if one press the Right mouse button on a component in the browser table/menue , a further menue appears. at the thirth entry downward the command: "auswahlsatz erstellen" appears. if you click, no Chance to create a selecting.
is their anything to do to activate this activity? Maybe in "preselecting table" or anywhere else? i tryed most, but now i have no ideea!
my opinion is: this menuepoint is needed to get different selection of component or Body Arrangements.
if there is anybody who could give me an ideea or an advice for running steps to get an selection of Body or commponent, that would be very nice.
thanks for helping me in Advance.
Solved by jhackney1972. Go to Solution.
I believe you are having issues with Create Selection Set, at least that is what Google Translate tells me. Take a look at the attached screencast, no sound, and see if you can see any difference in the process I used. It does not matter if you select the components before or after the command, the selection set is created. Bodies can be used as well as components. In my screen cast, I created a selection set then used it to select components for the Move / Copy command.
John Hackney, Retired
