I am a novice at F360 and I would like to print a model for the first time. The problem is when I create a view in the drawing, some former part that I should have delete are still showing. I deleted the view, came back to the model, cleaned again, they sure don't exist anymore, then come back to drawing and creat a new view, but the artifacts are still showing, thank you for showing me what I do wrong !
Solved by jhackney1972. Go to Solution.
Please attach your model to your post so the forum users can help you out.
John Hackney, Retired
Thank you,
I am not sure to understand, can you see my 2 images attached ? or do you need something else ?
Pictures may be worth a thousand words but the model to troubleshoot would be worth a hundred thousand. Put the shoe on the other foot. Do you think you could solve the problem not having the model to work with, probably not. Go to File -> Export to a folder of your choice on your computer then attach it under Attachments on your post.
OK sorry I didnt know this was possible since it was cloud based,
Thank you I just uploaded it,
Nothing is attached. Does the file have a .fd3 extension or a .fdz extension? FDZ are linked assemblies and easier to share from your Fusion Web Database. FD3 can easily be attached. Try again!
My mistake, it when to your first post message.
I created a 2D drawing and do not see the "artifacts" you indicate. I would try this. Close all models in Fusion 360. Open up the model your Exported and sent to me. You do that by selecting File ->Open, select My Computer and navigate to the file. Quickly do a 2D drawing of this model and see it there is a problem. If not, replace the cloud database file with the one you exported. A word of caution, Fusion 360 allows you to save files by the same name so I would give it a new name use File ->Save As.
By the way, on future posts do not attach pictures, embed them in the message as I have done here. It is a pain to have to open them for viewing. You capture the picture, place it on your computer and then use this icon to embed it in the message.
I wanted to attach my 2D drawing but forgot. Here it is.
Thank you so much John !
Everything worked perfectly fine after I followed your instructions,
Have a nice day!
