Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Angle bottom of design
3 REPLIES 3
oxicottin
145 Views, 3 Replies
Hello, I cant figure out how to add a section to the bottom of my net cup. The section needs to be around 5mm tall and angled inward like in the image, something like 45 degrees.  I have something that fits in the top cylinder and the angle piece is to prevent it from falling through the bottom.
3 REPLIES 3
jhackney1972
in reply to: oxicottin
The bottom wall is 5 mm thick, as per you specification.  If you want it thinner you can modify my revolve sketch.  Mode is attached.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
oxicottin
@jhackney1972 yes that is what I needed but hollow like the upper half, how can I do that?  Thanks!
jhackney1972
You can edit the bottom profile sketch, second from the last in the timeline, to another dimension if you want.  Model attached.
John Hackney
Retired
