Announcements
Alternative to "Alternate position view"
anders.frederiksen8K93F
Observer
Observer
Observer
Hi everyone!
So, I've been working with Fusion 360 for a while but I have always thought that it falls far behind other programs when working with drawings. Coming from SolidWorks I'm used to showing different positions when making drawings of assemblies to give the customer a clear view of different positions when for example a machine is moving. Is there anything similar in Fusion 360 that I can use to show different positions of for example an arm in lower and upper position? I tried capturing the positions in the assembly mode but there is apparently no way to use that in the drawings.
g-andresen
Have a look at ANIMATION > Create different storyboards > Create a drawing of each in the same drawing sheet
günther
Observer
Observer
Thank you for the fast reply! I have only made exploded views in ANIMATION before so I need a little help here. How do I move a part in ANIMATION so it follows a certain path and all the connected components move with it? All the parts seem to be fixed. I can move them in DESIGN but then they move in all storyboards.
