After update, I can't use fusion2urdf
826531725
Message 1 of 12
826531725
After update, I can't use fusion2urdf. There is no response after clicking run button.
syuntoku14/fusion2urdf: A Fusion 360 Script to export URDF (github.com)
Replies (11)
Message 2 of 12
JeromeBriot
The Python version has been updated to version 3.12 with the latest release of Fusion
The fusion2urdf script uses a module that is no longer supported in this version of Python.
=> https://docs.python.org/fr/3.11/library/distutils.html
Try to contact the author of the script : https://github.com/syuntoku14
Message 3 of 12
JeromeBriot
@826531725You can fix the problem by yourself.
Find the file utils.py in the utils subfolder where the script is located and open it with a text editor.
Replace line 12:
from distutils.dir_util import copy_tree
With:
from shutil import copytree
Replace line 152:
copy_tree(package_dir, save_dir)
With:
copytree(package_dir, save_dir, dirs_exist_ok=True)
Be careful to respect the indentation in the code.
Save the file and try to run the script.
Message 4 of 12
JeromeBriot
I just saw that there is a PR on the GitHub repo that fixes the problem: https://github.com/syuntoku14/fusion2urdf/pull/84
It's up to the author to merge this into the main code now.
Message 5 of 12
826531725
perfect solution! Thank you very much for your support
Message 6 of 12
826531725
Message 7 of 12
gil_vit
Thanks for solving this 😃
Message 8 of 12
cb_en_u4are22
Community Visitor
Community Visitor
It worked! Thank you Jerome.
Message 9 of 12
b012210278GF4M7
Observer
Observer
you are a hero
Message 10 of 12
Abinash_Mohanty
Community Visitor
Community Visitor
Hi sir,
Thanks for the solution
I have a issue now does fusion2urdf not support an assembly that has parts import from other design and assembly
What I am doing is I had one assembly then I use that in another design and create the final assembly and then trying to convert that final assembly
The reason I am doing this way because it's a studica bot, I am trying to replicate as close as possible so got the stl files from their website.
Pls if u need to see the .f3z file or anything please let me know-
[email protected]
Thank you for ur time sir.
Message 11 of 12
sanathtsk
Observer
Observer
not working
Message 12 of 12
Diojedit
Community Visitor
Community Visitor
Muchas gracias 🙂
