After Update 2.0.10244 Pipe command has issues
I am seeing problems with Pipe after the latest update. It seems like it is stuck on chain selection even when its not checked also it will make the pipe solid even when hollow is checked and section thickness is filled out. I have found if you toggle the chain box and the hollow box on and off and then select your line it seems to work correctly. Then if you use pipe again on another line you have to toggle the boxes again.
Replies (13)
jhackney1972
I cannot replicate your issues.  Could you please create a Screencast to demonstrate what you are seeing.  Be sure to show the Pipe dialog box as you demonstrate.
John Hackney, Retired
I made a video to show my issue's
jeff_strater
seems to work for me.  Have you tried restarting Fusion?
Jeff Strater
Engineering Director
Yes I have restarted it. I have tried it on 3 different computers same results I even did the clean uninstall and reinstall.
HughesTooling
@jeff_strater  The chaining checkbox bug has been around for ages, think it's in other commands as well. Your test you toggled it so didn't see the problem. It seems the hollow option has the same problem where it uses the default state not the last used state and what's showing on the dialog.
Screencast shows same behaviour as @Anonymous's example.
Mark
Mark Hughes
Owner, Hughes Tooling
Humm weird never had either issue come up ever until the last update. Pipe is my most used tool other than line I cant use any chains as the program for my plasma tube cutter doesn't like what Fusion exports if its made from a chain. I guess I'll have to live with double clicking each checkbox everytime I select pipe.
HughesTooling
@Anonymous  There is a chance it got fixed for a while. Can't remember what other commands I've seen the problem with.
Mark
Mark Hughes
HughesTooling
Here's another example using the surface version of revolve. Neither of these examples are features I use that often so I think there are some others. @jeff_strater  Do you need examples of all the features or will fixing one feature fix the others?
Mark
Mark Hughes
HughesTooling
Also a problem in sweep! Unchecked in first sweep second sweep has chain unchecked from previous use but still selects a chain.
Edit, this is a feature I use quite often and where the problem's been around for ages.
Mark Hughes
jeff_strater
ah. OK, good to know.  I remember another issue like this, where the command was not correctly setting the correct last value.  Yes, a list would be helpful, as this does tend to be command-specific.
Jeff Strater
Prophet_Barnes
I'm facing exactly the same issue and have observed the same behaviour with the pipe tool.
Issue seems fully fixed now in version 2.0.10440  Pipe tool works great now.
