Good afternoon. About two month ago i created a 3d debur toolpath that worked fine in simulation as well as on the actuall machine. last week i tryed again an it didnt work 😞
using the saved versions i returned to the point it was working, yet just regenerating the path "killed" it.
Before regenerating (with a valid toolpath!!)
After regnerating
The differences a "subtle" in the normal simulation. yet in the machine simulation and the real machine the tool drives through the part.
I think i probably changed some global stuff i can rememeber something like "allow automatic repositioning" or so but forgot where it was.
Thanks in advance!
It's likely that your tool is defined with a zero tip diameter. Try increasing that to a larger value and see if that solves your issue. Otherwise, would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
