Yet another SVG import problem
Please can someone help me. I am having huge issues importing an SVG and maitaining the correct scale. I have multiple files for a sign and every file seems to need a different scale to be the correct size.
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for posting!
May I know where you create the SVG file??
SVG units are screen units, so pixels. Unless the SVG translator options supports mapping logical units (in, mm, cm, etc.) to screen units (pixel dimensions, and these vary depending on what OS and version of OS you're using), which AI does not, we'll never get a 1:1 mapping of an SVG from AI to Fusion.
Have you seen this thread??
https://forums.autodesk.com/t5/design-validate-document/svg-scale-is-wrong/m-p/6560352?nobounce
If you need more help, please let me know Smiley Happy I will be happy to support you
Many thanks,
Ahreum.
