Message 1 of 15
Wrong head diameter for M3 Cap Screw
I've just started using Fusion 360, and tried to use an M3 Cap Screw with a clearance and pocket for the head. The head diameter is miles too big. How is this possible? Surely this is a component that has been used thousands of times, so why is it wrong? What's the point in having a library if you then have to go back and do things the old way to get the result you need?
Doesn't anyone take the time to fix these issues? Surely I'm not the first to find this and try to feed it back.
I tried to feed this back, but Autodesk doesn't let you feed back anything unless you are using a version with a subscription.
