Wireframe Visual Style appears unclear on Fusion360 30 day free trial
Greetings to the Autodesk Community,
I have started the 30 day free trial of Fusion360, began following the video tutorials on the software, and have found an issue.
When a model is uploaded, then opened onto the workspace, the Wireframe visual style view of the model appears in all Environment settings except the Photo Booth (white background) setting.
The only solution that has corrected this problem is to change Environment settings, then switch back to the Photo Booth setting.
ryan.bales
Autodesk Support
Autodesk Support
Hi @Anonymous,
This will not have anything to do with it being a trial as a trial is the full version without an active subscription.
I do not see this on my side. No edges are or wireframe are shown in any environment unless its enabled in the visual style setting.
It's possible this is an issue with your file/type or your graphics card/driver.
Ryan Bales
Fusion 360 Product Support
alexandwirtz
-> Visual Style Problem seems to persist!
I have the same experience on Mac (Ventura 13.5.2 (22G91)). I can hardly work like that and it keeps switching back some components to wireframe, some are not displayed at all. So far only using the wireframe visual styles work. Others are somewhat broken.
Please fix this. Thank you!
