Wireframe display not clear
Is anyone else experiencing an issue with the wireframe display after the recent update? Anyone know what to do to get a clear well-defined wireframe display? As you can see from below the wireframe is very intermittent. Not sure what is going on here.
** Bit of an update, I had a look at this post on a phone and found the wireframe below is actually very clear. Which is confusing because the wireframe display had been fine so far up until the most recent update.
Wireframe display issueWireframe display issueShaded with visible edges onlyShaded with visible edges only
So when I go from maximized display to windowed it momentarily displays the lines of the wireframe display clearly. I have attached the photo of this happening below despite knowing that on some screens there is no difference. I just hope someone else is seeing a difference.
jhackney1972
Yes, I see the same poor line quality when I use the Environment "Infinity Pool" or "Photo Booth" and the Visual Style of "Wireframe".  The other Environment settings see to display wireframe OK.  I also found it I turn off Effects, "Anti-Aliasing" in both the Environment "Infinity Pool" and "Photo Booth", the wireframe line quality improves greatly.
The screen captures below are using the Environment "Photo Booth" and Visual Style "Wireframe".  One is with Effects "Anti-Aliasing" checked and one with it unchecked.
There definitely is an issue.
John Hackney, Retired
Thank you @jhackney1972. That did seem to work for me too. I would agree, definitely something going on there. Thank you though as now my brain isn't going to explode when trying to look at wireframe displays.
just what i was looking for, thx!
